I am trying to configure authentication using Active Directory and I am following the documentation but I get an error message while running the lnms config:set auth_ad_url command.
The error message that I get is The value field format is invalid.
nmsadmin@librenms:~$ lnms config:set auth_ad_url ldaps://dc01.domain.local The value field format is invalid.
I am not sure what I am missing here, as I am using the exact same synthax as what’s in the documentation.
