I’m unsure what isn’t working here and why. I’m using Active Directory with LDAP v3. Base DNs for users and groups are set correctly. The error is in the log of ./auth_test, linked below.
Output of ./validate.php:
LibreNMS | 1.57-71-gc22fa1063
DB Schema | 2019_04_22_220000_update_route_table (147)
PHP | 7.2.24-0ubuntu0.18.04.1
MySQL | 10.1.41-MariaDB-0ubuntu0.18.04.1
RRDTool | 1.7.0
SNMP | NET-SNMP 5.7.3
That unfortunately didn’t seem to have any effect. The log from ./auth_test.php is the same after manually configuring the bind user, as well as removing the duplicate auth_ad_check_certificates entry.
Are there any AD specific changes or configurations I should have made on the controller to allow LibreNMS AD authentication?
Could not bind to AD, you will not be able to use the API or alert AD users
Seems you need to configure a specific bind account to query AD Ldap. Should be different from the user
