Hello dear Community!
I’m looking for your help regarding the use of the authentication through AD.
I’m able to set it up correctly and use it. But I encounter an issue when I try to use Groups that are contained in an OU which contains parenthesis.
A little example:
Using this DN:
CN=mygroup,OU=LocalGroup(Permissions),ou=company,dc=company,dc=tld
the filter used when I use ./scripts/auth_test.php -l -v is incorrect. Indeed, the filter generated uses () which leads to an incorrect filter. It should use OU=LocalGroup\28Permissions\29 instead of OU=LocalGroup(Permissions).
I did not find any solution yet to provide my own filter for the group access part to bypass this issue.
When using a DN without parenthesis it works great.
Any chance there’s a fix or some way to make this happen?
Thanks a lot! I’ll be available in case something is not clear.
(This RFC talks about the support of escaping parenthesis for ldap filters. https://www.rfc-editor.org/rfc/rfc2254.txt)
Robin
