master ← rudybroersma:ciscoiw
opened 07:00PM - 05 Mar 25 UTC
Per community request:
https://community.librenms.org/t/add-cisco-iw9165dh-seri…es-access-point/27292
#### Please note
> Please read this information carefully. You can run `./lnms dev:check` to check your code before submitting.
- [X] Have you followed our [code guidelines?](https://docs.librenms.org/Developing/Code-Guidelines/)
- [ ] If my Pull Request does some changes/fixes/enhancements in the WebUI, I have inserted a screenshot of it.
- [X] If my Pull Request makes discovery/polling/yaml changes, I have added/updated [test data](https://docs.librenms.org/Developing/os/Test-Units/).
#### Testers
After you are done testing, you can remove the changes with `./scripts/github-remove`. If there are schema changes, you can ask on discord how to revert.
