Hi all,
maybe I did read past it in the documentation or is it just not possible.
But I am looking for a way to add the ‘os-updates’ script results in the ‘device overview’ list.
Thx all!
Hi all,
Thx all!
can you post a screen shot of what you are talking about where you are trying add this?
Usually OS-updates shows in Apps
Hello Kevin,
The OS-updates are indeed visible (as graphs) in Apps → OS Updates.
This is nice for some historical overview, but there now way to sort of make a simple list view.
I would like to add a column to the device overview:
But is this even possible ?
Kind regards
Eases,
Im not sure if it’s possible… but I moved this feature requests.
Thanks for the quick reply’s!
