Add Device Error and No Graph data
I did a fresh install of LibreNMS on Oracle Linux 8 (Centos8) and using PHP 7.4 (instead of 7.3) following the instructions at (https://www.centlinux.com/2021/02/install-librenms-network-monitoring-tool-centos-8.html)
./validate.php shows everything looking good:
[librenms@f1lnms1 ~]$ ./validate.php
LibreNMS 21.3.0-46-g10cf97e58
DB Schema 2021_03_26_014054_change_cache_to_mediumtext (205)
PHP 7.4.6
Python 3.6.8
MySQL 10.3.27-MariaDB
RRDTool 1.7.0
SNMP NET-SNMP 5.8
[OK] Composer Version: 2.0.11
When I add a device I receive the error: Missing required parameter for [Route: device] [URI: device/{device}/{tab?}/{vars?}] [Missing parameter: device].
The device is added and SNMPP information is populated - CPU, Interfaces, etc.
Graphs are created, but contain no data.
Any help is greatly appreciated!
Update:
Did a clean install with PHP 7.3, still get the error when adding a device:
Polling is working, graphs are generating, and they contain data
Hi Guys.
I have the same error, I attach a screenshot for the error.
The device was added, but the error exist.
Best Regards.
LibreNMS 21.3.0-44-g422d1195c
DB Schema 2021_02_09_122930_migrate_to_utf8mb4 (205)
PHP 7.3.27-9+ubuntu18.04.1+deb.sury.org+1
Python 3.6.9
MySQL 10.5.9-MariaDB-1:10.5.9+maria~bionic
RRDTool 1.7.0
SNMP NET-SNMP 5.7.3
