Add PacketFlux SiteMonitor Base3 Classic
Requesting support for the Packetflux SiteMonitor Base3 Classic. The OIDs have changed since the SiteMonitor 2.
Vendor documentation/mibs: Documentation for PacketFlux SiteMonitor Base3 Classic
snmpwalk output: SiteMonitor3 snmpwalk - LibreNMS
If you need any further information please let me know.
Thanks.
+1 on this… I’ve been able to graph the relevant OID’s using the “Custom OID” function as a workaround.
@wildbill can you elaborate on the OID’s your graphing and how you got it to work right?
Here are the values I’m using under Custom OID as a workaround:
Power 1 1.3.6.1.4.1.32050.3.2.1.1.4.0.1
Power 2 1.3.6.1.4.1.32050.3.2.1.1.4.0.2
Temperature 1.3.6.1.4.1.32050.3.2.3.1.4.0.1
