The Juniper ACX710 is auto discovered as a 'generic ’ device and as such does not display Temperature graphs & OS etc., and of course displays the server icon.
-bash-4.2$ ./discovery.php -h 4dby.asr1
LibreNMS Discovery
4dby.asr1 3 generic
Load disco module core
OS: Generic Device (generic)
Runtime for discovery module ‘core’: 0.4110 seconds with 307912 bytes
SNMP: [8/0.40s] MySQL: [0/0.00s] RRD: [0/0.00s]
Unload disco module core
Load disco module os
Hardware:
OS Version:
OS Features:
Serial:
Runtime for discovery module ‘os’: 0.0790 seconds with 191552 bytes
SNMP: [4/0.07s] MySQL: [0/0.00s] RRD: [0/0.00s]
Unload disco module os
Load disco module ports
X…
Runtime for discovery module ‘ports’: 1.5660 seconds with 8296 bytes
SNMP: [5/1.52s] MySQL: [102/0.29s] RRD: [0/0.00s]
Unload disco module ports
Load disco module ports-stack
Runtime for discovery module ‘ports-stack’: 0.4100 seconds with 720 bytes
SNMP: [0/0.00s] MySQL: [1/0.00s] RRD: [0/0.00s]
Unload disco module ports-stack
Load disco module entity-physical
Caching OIDs: entPhysicalEntry entAliasMappingIdentifier…
Runtime for discovery module ‘entity-physical’: 0.9200 seconds with 14312 bytes
SNMP: [1/0.82s] MySQL: [27/0.15s] RRD: [0/0.00s]
Unload disco module entity-physical
Module [ entity-state ] disabled globally.
Load disco module isis
UU
Runtime for discovery module ‘isis’: 0.3050 seconds with 254064 bytes
SNMP: [1/0.16s] MySQL: [4/0.03s] RRD: [0/0.00s]
Unload disco module isis
Load disco module processors
Host Resources: …
Runtime for discovery module ‘processors’: 0.1270 seconds with 60592 bytes
SNMP: [2/0.12s] MySQL: [10/0.07s] RRD: [0/0.00s]
Unload disco module processors
Load disco module mempools
Runtime for discovery module ‘mempools’: 0.8760 seconds with 152424 bytes
SNMP: [2/0.07s] MySQL: [1/0.01s] RRD: [0/0.00s]
Unload disco module mempools
Module [ cisco-vrf-lite ] disabled globally.
Module [ cisco-mac-accounting ] disabled globally.
Module [ cisco-pw ] disabled globally.
Load disco module vrf
Runtime for discovery module ‘vrf’: 0.0060 seconds with 3576 bytes
SNMP: [0/0.00s] MySQL: [2/0.05s] RRD: [0/0.00s]
Unload disco module vrf
Module [ cisco-cef ] disabled globally.
Module [ slas ] disabled globally.
Module [ cisco-cbqos ] disabled globally.
Module [ cisco-otv ] disabled globally.
Module [ cisco-qfp ] disabled globally.
Load disco module ipv4-addresses
s.s.s.s.s.s.s.s.s.s.
Runtime for discovery module ‘ipv4-addresses’: 0.4310 seconds with 28720 bytes
SNMP: [11/0.38s] MySQL: [72/0.40s] RRD: [0/0.00s]
Unload disco module ipv4-addresses
Load disco module ipv6-addresses
Runtime for discovery module ‘ipv6-addresses’: 0.2150 seconds with 63824 bytes
SNMP: [7/0.20s] MySQL: [13/0.09s] RRD: [0/0.00s]
Unload disco module ipv6-addresses
Module [ route ] disabled globally.
Load disco module sensors
ENTITY-SENSOR: Caching OIDs: entPhysicalDescr entPhysicalName entPhySensorType entPhySensorScale entPhySensorPrecision entPhySensorValue entPhySensorOperStatus
Airflow:
Current:
Charge:
Dbm:
Fanspeed:
Frequency:
Humidity:
Load:
Loss:
Power:
Power_consumed:
Power_factor:
Runtime:
Signal:
State:
Count:
Temperature:
Tv_signal:
Bitrate:
Voltage:
Snr:
Pressure:
Cooling:
Delay:
Quality_factor:
Chromatic_dispersion:
Ber:
Eer:
Waterflow:
Percent:
Runtime for discovery module ‘sensors’: 0.7730 seconds with 76760 bytes
SNMP: [7/0.74s] MySQL: [34/0.22s] RRD: [0/0.00s]
Unload disco module sensors
Load disco module storage
aix_filesystem : hrStorage : .U…
Runtime for discovery module ‘storage’: 0.2390 seconds with 16280 bytes
SNMP: [5/0.22s] MySQL: [12/0.08s] RRD: [0/0.00s]
Unload disco module storage
Load disco module hr-device
Runtime for discovery module ‘hr-device’: 0.1030 seconds with 3904 bytes
SNMP: [2/0.10s] MySQL: [1/0.01s] RRD: [0/0.00s]
Unload disco module hr-device
Load disco module discovery-protocols
CISCO-CDP-MIB:
LLDP-MIB: …
Runtime for discovery module ‘discovery-protocols’: 6.6820 seconds with 434992 bytes
SNMP: [1/6.04s] MySQL: [32/0.26s] RRD: [0/0.00s]
Unload disco module discovery-protocols
Load disco module arp-table
em0.0:
bme0.0:
jsrv.1:
ae10.104:
xe-0/0/1.0:
xe-0/0/3.0:
xe-0/0/4.0:
xe-0/0/5.0:
xe-0/0/6.0:
xe-0/0/7.0:
xe-0/0/8.0:
xe-0/0/9.0:
xe-0/0/10.0:
xe-0/0/12.0:
xe-0/0/13.0:
xe-0/0/14.0:
xe-0/0/15.0:
xe-0/0/16.0:
xe-0/0/17.0:
xe-0/0/18.0:
xe-0/0/19.0:
xe-0/0/20.0:
xe-0/0/21.0:
xe-0/0/22.0:
xe-0/0/23.0:
ae100.920:
irb.920:
ae0.0:
Runtime for discovery module ‘arp-table’: 0.2480 seconds with 320016 bytes
SNMP: [2/0.23s] MySQL: [32/0.17s] RRD: [0/0.00s]
Unload disco module arp-table
Module [ discovery-arp ] disabled globally.
Module [ junose-atm-vp ] disabled globally.
Load disco module bgp-peers
AS212133 …
Runtime for discovery module ‘bgp-peers’: 0.1980 seconds with 4488 bytes
SNMP: [2/0.08s] MySQL: [9/0.06s] RRD: [0/0.00s]
Unload disco module bgp-peers
Load disco module vlans
IEEE8021-Q-BRIDGE-MIB VLANs: ver version1
VLAN 1
VLAN 920
VLAN 1010
VLAN 1014
Runtime for discovery module ‘vlans’: 0.4090 seconds with 39280 bytes
SNMP: [7/0.40s] MySQL: [5/0.02s] RRD: [0/0.00s]
Unload disco module vlans
Module [ vmware-vminfo ] disabled globally.
Module [ libvirt-vminfo ] disabled globally.
Module [ printer-supplies ] disabled globally.
Load disco module ucd-diskio
Runtime for discovery module ‘ucd-diskio’: 0.0600 seconds with 928 bytes
SNMP: [1/0.06s] MySQL: [1/0.00s] RRD: [0/0.00s]
Unload disco module ucd-diskio
Module [ applications ] disabled globally.
Load disco module services
Runtime for discovery module ‘services’: 0.0000 seconds with 720 bytes
SNMP: [0/0.00s] MySQL: [0/0.00s] RRD: [0/0.00s]
Unload disco module services
Load disco module stp
Instances:
Ports:
Runtime for discovery module ‘stp’: 0.0540 seconds with 52712 bytes
SNMP: [1/0.05s] MySQL: [2/0.01s] RRD: [0/0.00s]
Unload disco module stp
Load disco module ntp
Runtime for discovery module ‘ntp’: 9.3930 seconds with 280 bytes
Unload disco module ntp
Module [ loadbalancers ] disabled globally.
Module [ mef ] disabled globally.
Module [ wireless ] disabled globally.
Load disco module fdb-table
Q-BRIDGE-MIB:
Runtime for discovery module ‘fdb-table’: 0.1730 seconds with 40344 bytes
SNMP: [0/0.00s] MySQL: [5/0.02s] RRD: [0/0.00s]
Unload disco module fdb-table
Load disco module mpls
Runtime for discovery module ‘mpls’: 0.0000 seconds with 23456 bytes
Unload disco module mpls
Discovered in 15.396 seconds
SNMP [70/11.72s]: Snmpget[33/1.17s] Snmpwalk[36/10.50s] Snmpgetnext[1/0.05s]
SQL [376/2.01s]: Select[222/1.49s] Delete[7/0.02s] Update[144/0.47s] Insert[3/0.02s]
RRD [0/0.00s]:
-bash-4.2$
