Dejan
27 January 2021 22:56
1
QSFP optics are not discovered for these devices. Definition is present in Timetra-port-mib and its called tmnxDDMLaneEntry
here is an example
snmpbulkwalk -v2c -c public -OQUs -m TIMETRA-PORT-MIB -M /home/librenms/mibs:/home/librenms/mibs/nokia:/home/librenms/mibs/timos tmnxDDMLaneEntry
Output snippet:
tmnxDDMLaneTxOutputPower.1.1610899520.1 = 8912
tmnxDDMLaneTxOutputPower.1.1610899520.2 = 7580
tmnxDDMLaneTxOutputPower.1.1610899520.3 = 8076
tmnxDDMLaneTxOutputPower.1.1610899520.4 = 8709
Dejan
30 January 2021 23:52
2
Here is the complete OID for Lane 1 TX power where 1610899520 is ifIndex
.1.3.6.1.4.1.6527.3.1.2.2.4.66.1.12.1.1610899520.1
I’v managed to add it as custom OID but it would be nice to have it as part of OS
Dejan
2 September 2021 17:24
3
I just saw that there is a pull request for this and i wonder what needs to be done to make it go through
librenms:master
← kterobinson:feat/nokia_opticalpower_multilane
opened 07:54PM - 23 Aug 21 UTC
Description: Adding support for Nokia multilane optics in the dBm sensor.
DO… NOT DELETE THE UNDERLYING TEXT
#### Please note
> Please read this information carefully. You can run `./lnms dev:check` to check your code before submitting.
- [ ] Have you followed our [code guidelines?](https://docs.librenms.org/Developing/Code-Guidelines/)
- [ ] If my Pull Request does some changes/fixes/enhancements in the WebUI, I have inserted a screenshot of it.
#### Testers
After you are done testing, you can remove the changes with `./scripts/github-remove`. If there are schema changes, you can ask on discord how to revert.
skwang
2 September 2021 20:49
4
While I’m not the author, I can say this is being worked on. We have some code change requests and then to add unit test to the PR. Hopefully this will get merged soon.
Dejan
20 October 2021 11:43
5
This PR has been closed due to missing testdata. i’m a newbie when it comes to this but can i collect test data by testing this PR?
Will ./scripts/github-apply <pr_id> still work even if PR is closed?
Dejan
28 October 2021 19:37
6
Can someone give me an answer please?
zombah
29 October 2021 21:39
7
If this is not yours PR you need to:
1.fork original author repo and branch
2.commit your test data into it
3.submit your fork as new PR
