Adding admin users on LibreNMS
Hi, I’m new to Libre and have sort of an issue.
Colleague that was managing LibreNMS quit with the end of January, and I continued to do his work. He didn’t elevate rights for my user to admin level, and now I can’t add or remove users, nor do I have option to do so in my GUI.
He told me to use adduser.php tool on Linux, and when I do it says that user that I wanted to add was added successfully but I can’t log in with it to GUI. It says invalid credentials.
Command that I use looks like this: ./adduser.php username, password, level 1-10, email.Without commas ofcourse.
Any suggestions on what I’m doing wrong? I have been trying to do this for 2 days already and nothing seems to be working.
Below command works
./adduser.php test1234 test1234 10
you should not mention word “level” just give 10 for admin
I know, I didn’t type level in to command. As you can see, it says User added successfully on my previous entries but I still can’t log in with that user to web GUI.
can try lnms
lnms user:add testuser -p testpw -r admin
what does this command do? can I add admin role to already existing user with it, or does this "lnms user:add " creates a new admin user?
creates new user
can u paste here the exact command you are typing. of course you can change password to random before pasting here
ahh, mismatched syntax
lnms user:add -p yourpassword -r admin yourusername
i have tested with both syntax. works for me
Ok, I write it this way and this is the reply:
hmm that explains.
your installation not using mysqlauth
i never tried other auth methods, im using default mysqlauth
what’s the other one my installation could use? Active Directory?
there are multiple options
