Adding/Editing Devices Error 502
I upgraded to PHP v7.3.2, Since this update when I try to add a new device through web interface or update the snmp settings on an existing device I get a TimeOut 502 error page that comes up. The device is never added or updated.
Could this be because Im using php 7.3 instead of the recommended 7.2?
Unlikely related to version. Look for a related error in librenms.log and post it here.
In lebrenms.log Im seeing the below over and over
> [2019-02-21 13:08:33] production.ERROR: SQLSTATE[42000]: Syntax erro or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'L:\\ Label:Logs Serial Number 906bf7dc"" AND storage.storage_descr != ""/vmfs/vo' at line 1 (SQL: SELECT * FROM devices,storage WHERE (devices.device_id = 70 AND devices.device_id = storage.device_id) AND devices.type = "Server" AND storage.storage_descr NOT LIKE '%memory%' AND storage.storage_perc >= 90 AND storage.storage_descr != ""L:\\ Label:Logs Serial Number 906bf7dc"" AND storage.storage_descr != ""/vmfs/volumes/55916302-0f9fa955-4b78-8cdcd4ae1b40"") (SQL: SELECT * FROM devices,storage WHERE (devices.device_id = 70 AND devices.device_id = storage.device_id) AND devices.type = "Server" AND storage.storage_descr NOT LIKE '%memory%' AND storage.storage_perc >= 90 AND storage.storage_descr != ""L:\\ Label:Logs Serial Number 906bf7dc"" AND storage.storage_descr != ""/vmfs/volumes/55916302-0f9fa955-4b78-8cdcd4ae1b40"")
>     /opt/librenms/includes/alerts.inc.php:186
>     /opt/librenms/poller.php:162
>     /opt/librenms/poller.php 70 2019-02-21 13:08:33 - 1 devices polled in 9.854 secs
And in the error_log Im seeing this when the 504 error page comes up
>  2019/02/21 12:51:26 [crit] 1297#1297: *95838 open() "/var/lib/nginx/fastcgi/0/01/0000000010" failed (13: Permission denied) while reading upstream, client: 10.6.5.153, server: SERVERNAME, request: "POST /ajax/table/eventlog HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.3-fpm.sock:", host: "SERVERNAME", referrer: "http://SERVERNAME/eventlog/"
>         2019/02/21 12:51:33 [crit] 1297#1297: *95830 open() "/var/lib/nginx/fastcgi/1/01/0000000011" failed (13: Permission denied) while reading upstream, client: 10.6.5.153, server: SERVERNAME, request: "POST /ajax/table/eventlog HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.3-fpm.sock:", host: "SERVERNAME", referrer: "http://SERVERNAME/eventlog/"
>     2019/02/21 12:51:44 [error] 1297#1297: *95840 FastCGI sent in stderr: "PHP message: PHP Fatal error:  Allowed memory size of 134217728 bytes exhausted (tried to allocate 20480 bytes) in /opt/librenms/vendor/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php on line 158PHP message: PHP Fatal error:  Allowed memory size of 134217728 bytes exhausted (tried to allocate 69632 bytes) in /opt/librenms/vendor/composer/ClassLoader.php on line 444" while reading response header from upstream, client: 10.6.5.153, server: SERVERNAME, request: "POST /ajax/table/eventlog HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.3-fpm.sock:", host: "SERVERNAME", referrer: "http://SERVERNAME/eventlog/"
>     2019/02/21 12:51:50 [crit] 1297#1297: *95840 open() "/var/lib/nginx/fastcgi/2/01/0000000012" failed (13: Permission denied) while reading upstream, client: 10.6.5.153, server: SERVERNAME, request: "POST /ajax/table/eventlog HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.3-fpm.sock:", host: "SERVERNAME", referrer: "http://SERVERNAME/eventlog/"
>     2019/02/21 12:57:02 [crit] 1297#1297: *96304 open() "/var/lib/nginx/fastcgi/3/01/0000000013" failed (13: Permission denied) while reading upstream, client: 10.6.5.153, server: SERVERNAME, request: "POST /ajax/table/eventlog HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.3-fpm.sock:", host: "SERVERNAME", referrer: "http://SERVERNAME/eventlog/"
>     2019/02/21 13:07:44 [error] 1294#1294: *96332 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 10.6.5.153, server: SERVERNAME, request: "POST /addhost/ HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.3-fpm.sock", host: "SERVERNAME", referrer: "http://SERVERNAME/addhost/"
The web interface eventlog doesnt seem to show anything excpet events on the monitored devices.
This second line is 186 from alerts.inc.php
$sql = $rule['query'];
$qry = dbFetchRows($sql, array($device_id));
$cnt = count($qry);
for ($i = 0; $i < $cnt; $i++) {
    if (isset($qry[$i]['ip'])) {
        $qry[$i]['ip'] = inet6_ntop($qry[$i]['ip']);
#1 is an invalid alert rule
#2 says you are out of php memory
Below is GUI for the alert rule, what would make it invalid. Because there are 2 storage.storage_descr does it require OR instead on AND?
As for the PHP memory do I need to add RAM or is there a limit I need to set somewhere?
The quotes around the descr values…
It is a php setting in php.ini
That resolved those errors, and I can update devices now. Now I’m seeing this on the error log
Looks like my ipaddress is getting permission denied for somthing. I am the Admin though lvl 10.
2019/02/21 14:38:34 [error] 1291#1291: *96665 upstream timed out (110: Connection timed out) while reading response header from upstream, client: MYIPADDRESS, server: SERVERNAME, request: “POST /addhost/ HTTP/1.1”, upstream: “fastcgi://unix:/var/run/php/php7.3-fpm.sock”, host: “SERVERNAME”, referrer: “http://SERVERNAME/addhost/
The connection timeout is nginx trying to connect to php-fpm I believe.
Check browser developer console for errors and librenms.log again.
That was it thanks for your help.
