hi,
I am new in this Group and Just install LibreNMS in CentOs-7 with Apache, Please Someone Can Tell me How I can Add My own Linux Pc (Localhost) in Librenms for Monitoring its Devices.
First you will need to setup SNMP if you haven’t already. http://docs.librenms.org/Installation/Installation-CentOS-7-Apache/#configure-snmpd
Make a note of your community string you configured.
At the top of the page you should see devices. Go to Devices > Add device. For hostname type “127.0.0.1” or “localhost” (don’t include the quotes). For SNMP version you will probably be using v2c. Port is most likely 161. Protocol is probably UDP. For port association mode you can use ifindex. The community string is probably public unless you changed it during the install. Click add device and you should be good to go.
Thanks acgustafson . it will help me to resolve my problem
