This is my first time using LibreNMS. I have several units of the same device. Can I add one of them, and add custom OIDs, and then duplicate it and change the IP address for the other units? Thanks.
Welcome
Maybe if the device type requires custom OIDs it would be worth it to add a new device type?
If you are comfortable with a bit of coding, you can send in a pull request to Pull requests · librenms/librenms · GitHub - use others as examples.
If this is over your technical capabilities, I have seen the developers in this forum asking for the needed information to model the new device type. There is even a section here exactly for this: Device Requests - LibreNMS Community
