hey guys , im trying to add support to LibreNMS for the WUT thermometers version 57605 and 57614.
this is my validate.php
bash-5.1$ php validate.php
Component | Version |
LibreNMS | 22.6.0-2-g1056f28de |
DB Schema | 2021_02_09_122930_migrate_to_utf8mb4 (242) |
PHP | 7.4.30 |
Python | 3.9.10 |
MySQL | 10.5.13-MariaDB |
RRDTool | 1.7.2 |
SNMP | 5.9.1 |
[OK] Composer Version: 2.3.7
[OK] MySQl and PHP time match
now the issue is :
i’ve collected all the snmp-data via these commands:
php /opt/librenms/scripts/collect-snmp-data.php --full -o wut -v 57605 -h themometer1
php /opt/librenms/scripts/collect-snmp-data.php --full -o wut -v 57614 -h themometer2
but when i generate the .json file , there is no section that has enclose the sensors…
running this command :
php /opt/librenms/scripts/save-test-data.php -o wut -v 57605 -m sensors -d
php /opt/librenms/scripts/save-test-data.php -o wut -v 57614 -m sensors -d
even if i run the commands without -m , same result , the .json files have no sensor section created.
i’ve aslo uploaded the mibs for the respective devices, and renamed them as standard requested.
i don’t know what im doing wrong …any help would be welcomed.
thanks again.
Ervin.
