@murrant from commit 73cbd19b33419a4ef6fc97c230599fb6a5d0d7af I saw you updated test data in tests/data/routeros_crs317.json, tests/snmpsim/routeros_crs317.snmprec.
From the docs I have not been able to locate a method of getting a jumpstart of how to generate data for the ccr2116. Is there a method documented I have been unable to find. Of how to get startet generating (e.g. a script) the two aforementioned files (myself) for a ccr2116?
I have located https://github.com/librenms/librenms/blob/master/tests/snmpsim/README.md which looks like manual work is required. With no guidance about references to scripts that can be used to speed up the process.
