Admin permission removed when changing password via my settings
Hey, we just discovered (tested with multiple users) that when an admin user changes their password, the admin permissions are removed.
Another admin has to grant them again so the user can do anything again.
We use the mysql auth method.
This only happens if the user changes their password via my settings. If he does this via manage users, the permissions are not removed.
The same behavior is the case if the user only has global read permissions.
Acknowledged that I can replicate this. Hopefully it will get fixed soon
Fixed upstream now. Thanks for reporting
Thanks for the quick solution.
I have just tested it and it works perfectly.
