Hy all,
reading
https://community.librenms.org/t/alert-rule-for-amount-of-devices-down/22701
and making my own “Advanced Alerting Rules” I would like to start a library thread with smart and useful advanced alerting rules that might be worth sharing.
Please contribute and share your craziest SQL Queries, which actual solve some tricky alerting requirements. ![]()
To make a good start I offer the first two Alert Rules:
- Alert (for a device) if the device is down and there are 10 (adjustable) or more devices down at the same time. Can be refined by SQL Statement to match for decent hostnames of a Hypervisor Cluster, Location, …
SELECT *
FROM devices
WHERE (devices.device_id = ?)
AND devices.status=0
AND ((SELECT count(hostname) from devices where status=0) >= 10);
- Alert (for a device) Named $FOO-CPE-A if the corresponding Partner (so $FOO-CPE-B but not $BAR-CPE-B) is also down.
Can be used for checking that at least 1of2 devices delivering a service is online.
SELECT *
FROM devices AS d1
WHERE d1.device_id = ?
AND d1.status = 0
AND (
SELECT COUNT(*)
FROM devices AS d2
JOIN devices AS d3 ON LEFT(d2.hostname, LENGTH(d2.hostname) - 7) = LEFT(d3.hostname, LENGTH(d3.hostname) - 7)
WHERE d2.hostname LIKE '%-CPE-A' AND d2.status = 0
AND d3.hostname LIKE '%-CPE-B' AND d3.status = 0
) > 0;
Happy alerting!
