Welcome to the Oxidized help section.
You are free to ask any questions surrounding Oxidized, it does not need to be specific to LibreNMS integration.
I’m assuming you are using the http source for Oxidized, if so, wherever you are pointing it to is not accepting connections.
You need to check if you can access the LibreNMS api you have as the http source. The error is suggesting it’s trying https so maybe you had scheme: https set at some point.
Through http only I can access the Librenms web UI. Can you please suggest in which point i need to make change?
