After the last daily.sh update i have problems with librenms
Hallo,
I have sinds this weekend problems with my LibreNMS.
This moment the webpage is not running and if i check ./validate.php i see that there is no connection with the database.
[[email protected] ~]$ ./validate.php
In ClassLoader.php line 444:
include(/opt/librenms/vendor/composer/…/…/app/Providers/ViewServiceProvider.php): failed to open stream: No such file or directory
LibreNMS 1.64.1-2-g90d4ef710
DB Schema Not Connected (0)
PHP 7.2.11
Python 3.6.8
MySQL ?
RRDTool 1.7.0
SNMP NET-SNMP 5.8
[OK] Composer Version: 1.10.6
You have new mail in /var/spool/mail/librenms
Also if i start a ./daily.sh i see the same errors
[[email protected] ~]$ ./daily.sh
Updating SQL-Schema OK
Cleaning up DB OK
My operating system is CentOS 8.
Thank you for you help.
Kind regards, Jorg
run ./scripts/composer_wrapper.php install --no-dev
Hello The Great Doc,
Thank you for you reaction
unfortunately the run script doesn’t solved the issue, her the output of the command:
[[email protected] ~]$ ./scripts/composer_wrapper.php install --no-dev
Nothing to install or update
Package spatie/laravel-cors is abandoned, you should avoid using it. Use laravel/framework instead.
Deprecation Notice: Class Wpb\String_Blade_Compiler\Facades\StringBlade located in ./vendor/wpb/string-blade-compiler/src/Facade/StringBlade.php does not comply with psr-4 autoloading standard. It will not autoload anymore in Composer v2.0. in phar:///opt/librenms/composer.phar/src/Composer/Autoload/ClassMapGenerator.php:201
Deprecation Notice: Class HTMLPurifier_Language_en_x_test located in ./vendor/ezyang/htmlpurifier/library/HTMLPurifier/Language/classes/en-x-test.php does not comply with psr-0 autoloading standard. It will not autoload anymore in Composer v2.0. in phar:///opt/librenms/composer.phar/src/Composer/Autoload/ClassMapGenerator.php:201
Deprecation Notice: Class Crypt_CHAP_MD5 located in ./vendor/dapphp/radius/lib/Pear_CHAP.php does not comply with psr-0 autoloading standard. It will not autoload anymore in Composer v2.0. in phar:///opt/librenms/composer.phar/src/Composer/Autoload/ClassMapGenerator.php:201
Deprecation Notice: Class Crypt_CHAP_MSv1 located in ./vendor/dapphp/radius/lib/Pear_CHAP.php does not comply with psr-0 autoloading standard. It will not autoload anymore in Composer v2.0. in phar:///opt/librenms/composer.phar/src/Composer/Autoload/ClassMapGenerator.php:201
Deprecation Notice: Class Crypt_CHAP_MSv2 located in ./vendor/dapphp/radius/lib/Pear_CHAP.php does not comply with psr-0 autoloading standard. It will not autoload anymore in Composer v2.0. in phar:///opt/librenms/composer.phar/src/Composer/Autoload/ClassMapGenerator.php:201
Illuminate\Foundation\ComposerScripts::postAutoloadDump
@php artisan package:discover --ansi
In ProviderRepository.php line 208:
Class ‘App\Providers\ViewServiceProvider’ not found
Script @php artisan package:discover --ansi handling the post-autoload-dump event returned with error code 1
Maybe handy but her is also my “git status” i hope this wil help to find the problem.
[[email protected] ~]$ git status
On branch master
Your branch is up to date with ‘origin/master’.
Untracked files:
(use “git add …” to include in what will be committed)
    fixrights.sh
    http_fping.mod
    http_fping.pp
    http_fping.tt
    phpMyAdmin-4.9.1-all-languages.tar.gz
    poller-wrapper-old.py
nothing added to commit but untracked files present (use “git add” to track)
At this moment it LibreNMS works agian. I can connect with the webgui of Librenms again and see some graphs of diverent devices.
This is created after i remove de directory “/opt/librenms” and reinstall librenms.
The mariadb was not reinstalled so i kept all the data in the database.
But now i see a lot of performance issues.
Like high cpu of the server, poller with a pollertime of more than 6000 sec and devices unpolled.
How can i solved this problem?
Output validate.php:
./validate.php
LibreNMS 1.64.1
DB Schema 2020_04_06_001048_the_great_index_rename (165)
PHP 7.2.11
Python 3.6.8
MySQL 10.3.17-MariaDB
RRDTool 1.7.0
SNMP NET-SNMP 5.8
[OK] Composer Version: 1.10.7
WARNING: pip is being invoked by an old script wrapper. This will fail in a future version of pip.
Please see https://github.com/pypa/pip/issues/5599 for advice on fixing the underlying issue.
To avoid this problem you can invoke Python with ‘-m pip’ instead of running pip directly.
