AFTER UPGRADE TO 24.2.0 many graph drops
LibreNMS 24.2.0 (2024-02-27T20:54:10+02:00)
DB Schema 2024_02_07_151845_custom_map_additions (290)
PHP 8.1.18
Python 3.8.10
Database MariaDB 10.3.39-MariaDB-0ubuntu0.20.04.2
SNMP 5.8
[OK] Composer Version: 2.7.1
after upgrade to latest version all graph is drops i reboot more than time nothing changed note that before the update system was work fine im using 38 worker i have like 2300 device total polled time 592 with so many unpolled devices , im using normal poller can u help me please
You could have a look at poller graphs before and after and see if some modules are taking longer etc.
Or you could just adjust your worker count up if your host has spare CPU/disk io cycles.
Do you have rrdcached configured as that can help substantially if disk IO is high?
the problem is after upgrading poller module graphs not showing up like image attached
I have the same issue, did you resolve it ?
Are you using cron polling or the SystemD service?
using crond polling yes
still not fixing it
