Airos devices changed to generic
We have an issue since the 26.6.1 update where all our AirOS devices are now discovered as generic devices. We have checked and the correct .1.3.6.1.4.1.41112.1.4 OID is returned by the device and we verified that the airos.yaml has the correct string for the sysObjectID. Any ideas where we should check next?
discovery output https://paste.rs/XsOR1
poller output https://paste.rs/tKKLm
LibreNMS  | 26.6.1-dev.15+36918f032 (2026-05-21T17:20:36-05:00)
DB Schema | 2026_05_15_144037_add_snmp_engine_id_to_devices_table (387)
PHP       | 8.4.21
Python    | 3.13.5
Database  | MariaDB 11.8.6-MariaDB-0+deb13u1 from Debian
SNMP      | 5.9.4.pre2
[OK]    Composer Version: 2.9.8
[OK]    Python wrapper cron entry is not present
[OK]    Redis is functional
Update your install
We are on the latest codebase of 26.6.1 “honestly, I thought we were on the monthly release, not daily”. Is there a newer version than what came out yesterday?
git checkout master
Already on 'master'
Your branch is up to date with 'origin/master'.
./daily.sh
Clearing caches                                    OK
Updating to latest codebase                        OK
Updating Composer packages                         OK
Updating SQL-Schema                                OK
Cleaning up DB                                     OK
Caching PeeringDB data                             OK
Sorry, hadn’t actually merged it in. Update and run discovery.
You’re on daily.
After you’ve updated run lnms config:set update_channel release and leave it to update on a monthly release.
Thanks, that fixed it. Changed back to monthly, I have no clue how that was changed to begin with.
