[librenms@toc-libremontst ~]$ /opt/librenms/discovery.php -h XX.XX.XX.XX -m os -d
LibreNMS Discovery
SQL[select migration from migrations order by id desc limit 1 0.57ms]
SQL[select count(*) as aggregate from migrations 0.34ms]
SQL[select version() 0.22ms]
| LibreNMS | 22.10.0-102-g3e6ad9006 (2022-11-09T12:07:08-05:00) |
| DB Schema | 2022_08_15_084507_add_rrd_type_to_wireless_sensors_table (248) |
| PHP | 8.1.11 |
| Python | 3.6.8 |
| Database | MariaDB 10.6.10-MariaDB |
| RRDTool | 1.7.0 |
| SNMP | 5.8 |
| DEBUG! | |
| Updating os_def.cache | |
| Override discovery modules: os | |
SQL[SELECT * FROM devices WHERE disabled = 0 AND hostname LIKE ‘XX.XX.XX.XX’ ORDER BY device_id DESC 1.3ms] |
SQL[select * from devices where device_id = ? limit 1 [102] 0.34ms]
SQL[select * from devices_attribs where devices_attribs.device_id = ? and devices_attribs.device_id is not null [102] 0.24ms]
10.60.9.14 102 aix [FPING] ‘/usr/sbin/fping’ ‘-e’ ‘-q’ ‘-c’ ‘3’ ‘-p’ ‘500’ ‘-t’ ‘500’ ‘-O’ ‘0’ ‘10.60.9.14’
response: xmt/rcv/%loss = 3/3/0%, min/avg/max = 0.37/0.43/0.52
SNMP[‘/usr/bin/snmpget’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/ibm’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQXUte’ ‘udp:HOSTNAME:161’ ‘SNMPv2-MIB::sysObjectID.0’]
SNMPv2-MIB::sysObjectID.0 = SNMPv2-SMI::enterprises.*.1.1.3
Modules status: Global+
OS
Device
Load disco module core
Attempting to initialize OS: aix
Attempting to initialize Group OS: unix
OS initialized: LibreNMS\OS\Shared\Unix
SNMP[‘/usr/bin/snmpget’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/ibm’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQXUte’ ‘-On’ ‘udp:HOSTNAME:161’ ‘SNMPv2-MIB::sysObjectID.0’ ‘SNMPv2-MIB::sysDescr.0’ ‘SNMPv2-MIB::sysName.0’]
...0 = ....3
...0 = IBM PowerPC CHRP Computer
Machine Type: 0x0800004c Processor id: 00F903A64C00
Base Operating System Runtime AIX version: 07.02.0004.0000
TCP/IP Client Core Support version: 07.02.0004.0000
..*.0 = balto
TCP/IP Client Core Support version: 07.02.0004.0000 | .1.3.6.1.4.1.2.3.1.2.1.1.3 |
OS: AIX (aix)
Runtime for discovery module ‘core’: 0.0370 seconds with -277440 bytes
SNMP: [1/0.02s] MySQL: [0/0.00s] RRD: [0/0.00s]
Unload disco module core
OS
Device
Load disco module os
Yaml location data:
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/ibm’ ‘udp:HOSTNAME:161’ ‘SNMPv2-MIB::sysLocation.0’]
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-Ovq’ ‘-m’ ‘SNMPv2-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/ibm’ ‘udp:HOSTNAME:161’ ‘sysContact.0’]
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OUQ’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/ibm’ ‘udp:HOSTNAME:161’ ‘IBM-AIX-MIB::aixSeSerialNumber.0’ ‘IBM-AIX-MIB::aixSeMachineType.0’]
IBM-AIX-MIB::aixSeSerialNumber.0 = “IBM,02210XXXX”
IBM-AIX-MIB::aixSeMachineType.0 = “IBM,8205-E6D”
Yaml OS data: {“IBM-AIX-MIB::aixSeSerialNumber.0”:“IBM,02210XXXX”,“IBM-AIX-MIB::aixSeMachineType.0”:“IBM,8205-E6D”}
Reporting disabled by user setting
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OUQ’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/ibm:/opt/librenms/mibs/dell’ ‘udp:HOSTNAME:161’ ‘MIB-Dell-10892::chassisModelName.1’ ‘MIB-Dell-10892::chassisServiceTagName.1’]
MIB-Dell-10892::chassisModelName.1 = NULL
MIB-Dell-10892::chassisServiceTagName.1 = NULL
SNMP[‘/usr/bin/snmpget’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/ibm’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQXUte’ ‘udp:HOSTNAME:161’ ‘NET-SNMP-EXTEND-MIB::nsExtendOutput1Line.“distro”’ ‘.1.3.6.1.4.1.2021.7890.1.3.1.1.6.100.105.115.116.114.111’ ‘.1.3.6.1.4.1.2021.7890.1.101.1’]
NET-SNMP-EXTEND-MIB::nsExtendOutput1Line[distro] = NULL
UCD-SNMP-MIB::ucdavis.78*.. = NULL
UCD-SNMP-MIB::ucdavis.78* = NULL
SNMP[‘/usr/bin/snmpget’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/ibm’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQXUte’ ‘udp:HOSTNAME:161’ ‘NET-SNMP-EXTEND-MIB::nsExtendOutput1Line.“hardware”’ ‘.1.3.6.1.4.1.2021.7890.2.4.1.2.8.104.97.114.100.119.97.114.101.1’ ‘.1.3.6.1.4.1.2021.7890.2.101.2’]
NET-SNMP-EXTEND-MIB::nsExtendOutput1Line[hardware] = NULL
UCD-SNMP-MIB::ucdavis.78*...114.101.1 = NULL
SNMP[‘/usr/bin/snmpget’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/ibm’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQXUte’ ‘udp:HOSTNAME:161’ ‘NET-SNMP-EXTEND-MIB::nsExtendOutput1Line.“manufacturer”’ ‘.1.3.6.1.4.1.2021.7890.3.4.1.2.12.109.97.110.117.102.97.99.116.117.114.101.114.1’ ‘.1.3.6.1.4.1.2021.7890.3.4.1.2.6.118.101.110.100.111.114.1’ ‘.1.3.6.1.4.1.2021.7890.3.101.1’]
NET-SNMP-EXTEND-MIB::nsExtendOutput1Line[manufacturer] = NULL
UCD-SNMP-MIB::ucdavis.78*....101.114.1 = NULL
UCD-SNMP-MIB::ucdavis.78...1 = NULL
SNMP[‘/usr/bin/snmpget’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/ibm’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQXUte’ ‘udp:HOSTNAME:161’ ‘NET-SNMP-EXTEND-MIB::nsExtendOutput1Line.“version”’]
NET-SNMP-EXTEND-MIB::nsExtendOutput1Line[version] = NULL
SNMP[‘/usr/bin/snmpget’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/ibm’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OQXUte’ ‘udp:HOSTNAME:161’ ‘NET-SNMP-EXTEND-MIB::nsExtendOutput1Line.“serial”’ ‘.1.3.6.1.4.1.2021.7890.4.4.1.2.6.115.101.114.105.97.108.1’ ‘.1.3.6.1.4.1.2021.7890.4.101.1’]
NET-SNMP-EXTEND-MIB::nsExtendOutput1Line[serial] = NULL
UCD-SNMP-MIB::ucdavis.78*...1 = NULL
Hardware: NULL NULL [NULL]
OS Version: 7.2.4.0
OS Features: NULL
Serial: NULL
Runtime for discovery module ‘os’: 0.2290 seconds with 78896 bytes
SNMP: [10/0.22s] MySQL: [0/0.00s] RRD: [0/0.00s]
Unload disco module os
SQL[UPDATE devices set last_discovered=NOW(),last_discovered_timetaken=? WHERE device_id = ? [1.318,102] 1.06ms]
Discovered in 1.318 seconds
/opt/librenms/discovery.php 10.60.9.14 2022-11-10 08:15:35 - 1 devices discovered in 1.562 secs
SNMP [12/0.28s]: Snmpget[12/0.28s]
SQL [8/0.05s]: Select[7/0.04s] Update[1/0.01s]
RRD [0/0.00s]:
