I’d start by checking if the sensor file has thresholds defined.
One of the references I found for this Sensor was at /opt/librenms/tests/data/enexus_smartpacks.json :
If that is the correct file, then the next step would be to define the limits and then check if the Alert rule for Sensors is enabled.
