I have several DC switches in my environment that Libre currently monitors what it calls “DCDC Input Voltage”
I want to be able to create an alert rule that specifies these switches only, and to alert if the Input voltage drops below a certain threshold (so that I know the switch is likely running on battery)
any help as to how I should create the alert rule would be appreciated.
