LibreNMS 1.38-59-g052b9d1
DB Schema 247
PHP 7.0.19
MySQL 5.5.52-MariaDB
RRDTool 1.4.8
SNMP NET-SNMP 5.7.2
hi all
I tried to pass
(%ports.ifOutOctets_rate8/1000000) When you want traffic above 20MB, send an alert.
But actually the test error is very great. Less than 1MB will also jump out
I added a check of %value.ifInOctets_rate 8/1000000 to the issued warning letter.
I also get a lot of values below 20MB or even less than 1M
Please help
reference:
https://groups.google.com/forum/#!topic/librenms-project/tNa3m6DXEs0
https://github.com/librenms/librenms/issues/2102
Switch to HTML Alerts stops alert notification
Port Utilization Alerts
We have examples in the alert rules collection.
Post a screen shot of the alert rule you are working on.
also i think you mean mb not MB.
I found that this setting is correct for vlan but it does not respond to port
Up to 200MB
ports.ifOutOctets_rate >= 200000000 AND ports.ifInOctets_rate >= 200000000
critical Max: -1
Delay: 60
Interval: 60
ssxzss:
200000000
If I set the following, it will jump out to 200MB or less to 1MB.
Up to 200MB(200000000)
ports.ifOutOctets >= 200000000 AND ports.ifInOctets >= 200000000
critical Max: -1
Delay: 60
Interval: 60
Are trying to to alert on bandwidth usage or how much traffic has been submitted.
For bandwidth use this alert rule and change the percent to fit your needs.
If your are trying to alert on how much data is passed through set up billing
The use of the port I test is also a bit abnormal later reference
opened 05:00PM - 10 Oct 15 UTC
closed 08:33AM - 09 Mar 16 UTC
Alerting
When I update the speed of a port via the devices edit page, with [X] X being th… e number of Mbits, the device sees the update, but the alert doesn't.
For example:
2015-10-10 15:20:16 1/0/13 speed: 2 -> 12
2015-10-10 17:35:29 1/0/13 speed: 12 -> 15
https://imgur.com/Mp75Ypd
If you need any further information, let me know.
Will work properly
Because traffic is monitored for persistent abnormal (small) traffic, traffic per port is required instead of percentage
Please help again Thanks
What’s more surprising is that the percentage calculation is correct. The percentage calculation was abnormal.
