Hello!
I was working on adding alert acknowledgement option from transport messages, so that we could acknowledge them without going to the web interface.
There is a simple API ack_alert
request in the script, which only requires alert_id to be passed. I thought that maybe one of the template placeholders could be expanded to the alert id and then easily passed to API call, so added both %id and %uid to the template to see what is required. But it seems that both placeholders expand to values from alert_log table.
Last PROBLEM alert contents for ids:
Timestamp: 2018-06-20 14:35:12
Faults:
#1: sensor_id => 7051; sensor_oid => .1.3.6.1.4.1.11.2.14.11.5.1.82.1.1.1.1.13.49; sensor_descr => 49 Port Bias Current;
Sensor: 0.016116
Previous Measurement:
Limit: 0 / 0.01
Alert ID:
Alert UID: 213154
ACK URL: https://librenms/test.php?id=213154
Note that %id is not expanded at all in problem alert.
It will be expanded with recovery event, but will not be the same as %uid, however from the same table.
Alert rule template:
Last IDs from alerts at about the same time (alert delay is 5m, so there is a threshold):
select id from alerts order by id desc limit 10;
| id |
| 37293 |
| 37292 |
| 37291 |
| 37290 |
| 37289 |
| 37288 |
| 37287 |
| 37286 |
| 37285 |
| 37284 |
Last IDs from alert_log at about the same time (alert delay is 5m, so there is a threshold):
select id from alert_log order by id desc limit 10;
| id |
| 213155 |
| 213154 |
| 213153 |
| 213152 |
| 213151 |
| 213150 |
| 213149 |
| 213148 |
| 213147 |
| 213146 |
Can somebody please approve if this is expected behavior or a bug? In the latter case, can somebody point out which code block should be reviewed for fix (if it is something simple, I can try fixing this myself)?
./validate.php output:
LibreNMS | 1.40-23-g68a6766
DB Schema | 252
PHP | 5.6.30-0+deb8u1
MySQL | 5.7.20
RRDTool | 1.6.0
SNMP | NET-SNMP 5.7.2.1
[OK] Composer Version: 1.6.5
[FAIL] Database: extra table (plugin_config_rules)
SQL Statements:
DROP TABLE `plugin_config_rules`;
[FIX] Check your poll log and see: http://docs.librenms.org/Support/Performance/
Devices:
<device list>
[FAIL] Some devices have not completed their polling run in 5 minutes, this will create gaps in data.
Devices:
<device list>
[FIX] chown -R librenms:librenms /opt/librenms
Files:
/opt/librenms/html/test.php
