I have imported the default alert rules.
The rule called Port utilisation over threshold is great, but doesn’t work well on vlan-interfaces. Because SVI’s are usually reported as 1Gbps ports.
Is it possible to expand on this rule to ignore vlan-interfaces? I am using mostly Cisco equipment.
I know that I can manually set interface speed in LibreNMS, but thats a lot of ports to cover, and remember to do manually, so I rather just ignore vlan-interfaces completely.
