i have a librenms installed with docker.
works great (Thank you!)
i setup application certificate
works fine, but i try to add a sort of alert if
Certificate Remaining Days < 10
i think to use
applications_metric.value less 10
but how i can define “Certificate Remaining Days” ???
i search applications.name or similar but i can’t found nothing…
can you help me please?
thank you
Usually your best bet is to explore the applications and application_metrics tables.
TBH I’ve never seen this particular app, so this is just a guess based on the application polling code , but maybe something like…
applications.app_type = “certificate”
application_metrics.metric = “remaining_days”
application_metrics.value < 10
Thank yuo for reply.
i try
applications.app_type EQUAL certificate
AND
application_metrics.metric EQUAL remaining_days
AND
application_metrics.value < 40
i have some certs with 35-38 remainin days but i have no alert…
after i try
AND
but nothing…
do you have some ideas?
thank you in advance
If you’re able to, trying running this query to get a better look at the data…
SELECT devices.hostname, devices.sysName, applications.device_id, applications.app_id, applications.app_state, application_metrics.metric, application_metrics.value
FROM devices,applications,application_metrics
WHERE (devices.device_id = applications.device_id)
AND (applications.app_id = application_metrics.app_id)
AND app_type = 'certificate'
It looks like the application_metrics.metric field is actually: [fqdn]_remaining_days
So if you change the application_metrics.metric piece of your alert to…
application_metrics.metric ends with “_remaining_days”
…I think you’ll be set.
system
Closed
23 November 2025 14:44
5
