Hi, Guys.
I need to alert on various drives within a Windows Server. The documentation only seems to show how to do this for Linux root directory ‘/’. This works fine.
I tried setting the alert rule as the following to alert if the C, D, E, F, or G drive has less than 10% space left.
storage.storage_descr = "F:" AND storage.storage_perc >= 90
But I get the following error on event logs and it doesn’t alert:
Error in alert rule F Drive has less than 10% free space (40): SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ‘"F:" AND storage.storage_perc >= 90’ at line 1 (Connection: mysql, SQL: SELECT * FROM devices,storage WHERE (devices.device_id = 65 AND devices.device_id = storage.device_id) AND storage.storage_descr = "F:" AND storage.storage_perc >= 90)
This is the same on any drive letters. Can’t seem to find a topic in the forums which addresses this either.
Thank you,
James Stoner
