Hi, can i ask if it is possible to make an alert when you billed traffic? and if so, how can i make this alert.
You’ll need to provide a bit more info on what it is you actually want to alert on. I expect the answer might be no in this case though.
I would like to have alerts with the billed traffic, alerting me whenever the user exceeds the quotes. for example if i set a quota of 500mb then the user uses more than 50% of the quota, it should will send an alert through HipChat or email. Would that be possible? and also I already made an alert rule like this: %macros.bill_quota_over_quota >= “75”, but it doesn’t send a notification.
Billing info doesn’t link to devices from what I can see so this doesn’t look possible.
ah, ok thanks for your answer.
