I am trying to integrate Librenms with Freshservice (ITSM). Freshservice has the ability to do custom integrations through webhooks api.
“You can integrate via webhook channel of your monitoring tool to send alerts to Freshervice.”
The question it is asking is for me to copy the alert payload into their system in JSON format. I googled it and found an MS Teams JSON in the DOCS but don’t know if that would work here or not.
Can you supply or do you have the alert payload in JSON format?
“Copy the alert payload structure sent from your monitoring tool in JSON format and paste it below. You can map the alert fields sent from your monitoring tool to Freshservice fields in the next screen.”
This would be an awesome integration and if I can get it to work I will write detailed instructions. Please assist
