This is a question about alerting. I go to Alerts -> Notifications.
Once there I see some alerts (created by the stock alerts templates “out-of-the-box” by LibreNMS). For example, say a port is down. There are several columns like Status/Rule/Hostname/Severity/Acknowledge/etc. The last column says “Procedure”. It has “Open” buttons for each row of alerts underneath it. So when I try to open an alert I receive a red error box at the top right hand of the screen that says…
“An error occurred opening procedure for this alert. Was the procedure link configured?” It does it for every alert. Again this is the stock alert templates from LibreNMS. It was not doing this before. Anythoughts about that error?
Below is my validate.php…
Component | Version |
LibreNMS | 2ba7093d9cXXXXXXXXXXXXXXdf00a31b667525f6804 |
DB Schema | 199 |
PHP | 7.0.20 |
MySQL | 5.5.52-MariaDB |
RRDTool | 1.4.8 |
SNMP | NET-SNMP 5.7.2 |
[WARN] Your install is out of date, last update: Tue, 04 Jul 2017 21:41:22 +0000
