Hi there,
I’m trying to create an alert rule that checks the response time of a webserver we’re monitoring with LibreNMS.
So far I have set ip the host as a ping-only device with check_http enabled as a service. I also found an alert rule that is triggered when the service status is critical. So that is all working as expected.
Now we would also like to have an alert if the response time is over a certain threshold. Is that possible?
Yes setup a delay in the alert rule.
