i have n°3 Cisco 3750G in Stack configuration (one management IP); is possible to create a rule to monitoring each single switch, stack member, and receive email if one of these is down?
Hello Lycos,
Yes, you can monitor the “state” of the stacks and create alerts when they change or fail. I have a Cisco 6800 VSS stack that shows these state, and you can track any change here. Cisco 3750G show equivalent states that you can use.
PipoCanaja
Hi, PipoCanaja
sorry, but in the state I only view “fan” and “power supply” status of the 3 switch; in ‘inventory’ librenms indicate “Cat37xx Stacking” and I view the single serial number/model of the member stack.
How can I monitorate the health status of the member? (in alert editing is there any ‘sensor type’ for this?)
Thanks!
