In the last two days, alert rules have stopped using their assigned templates and are instead using the default template. I’ve attempted to remove their template assignment and set it again, but the behavior doesn’t change. When I look at the database, I see the correct assignments, so I’m not sure why it isn’t working.
Database contents: Database - LibreNMS
LibreNMS | 22.7.0-36-gb12400861
DB Schema | 2022_07_03_1947_add_app_data (244)
PHP | 8.1.8
Python | 3.8.10
Database | MariaDB 10.3.34-MariaDB-0ubuntu0.20.04.1
RRDTool | 1.7.2
SNMP | 5.8
[OK] Composer Version: 2.3.10
[OK]
[OK] MySQl and PHP time match
