Hi all, I’ve just setup a new instance of LibreNMS and having issues with the Alert Rules where the rules are matching but not triggering the Alert.
For example, the default rule ‘Device Down! Due to no ICMP response.’ is matching a switch I pulled the cable from as a test. Capture debug for alerts shows the rule is matching however the Rule isn’t triggering the alarm and isn’t showing the alarm against the service or dashboard. Not even showing up in Alert History.
Any help would be appreciated, thanks!
