ALERT_Switch_Port_Lastchanged
In LibreNMS, Port tab we can see the different status changed (see on image)
I would like to be able to use “time” of status changed in alerts.
The final goal is to set an alert:
If ports.ifAdminStatus eqaul up
and ports.ifOperstatus equal down
and => (this is the one I can’t find) that the port status is greater than X days
As you have understood, the goal is to find the switch ports that have not been used for a while.
Thank you very much
I don’t have an actual query to assist, but some pre-work to assist you is here: Unused ports more than 30 days
