My template is sending emails that contains :
Alert sent to: Warning! Fallback template used due to error in template CSSVT - Équipements up/down: Undefined constant “critical”
Only word critical in the template “template CSSVT - Équipements up/down” is this part :
@if ($alert->state == 1)
@if ($alert->severity == critical){{ $alert->severity }} @endif
@if ($alert->severity == warning){{ $alert->severity }} @endif
@endif
I’m sending the ./validate.php. I’m reading the docs, but I don’t find the explanation for this error. Can you help ?
Component
Version
LibreNMS
23.11.0-8-g90927be97 (2023-11-27T21:38:41-05:00)
DB Schema
2023_11_21_172239_increase_vminfo.vmwvmguestos_column_length (274)
PHP
8.1.2-1ubuntu2.14
Python
3.10.12
Database
MariaDB 10.6.12-MariaDB-0ubuntu0.22.04.1
RRDTool
1.7.2
SNMP
5.9.1
[OK] Composer Version: 2.6.5
[OK] MySQl and PHP time match
[OK] Redis is functional
laf
28 November 2023 21:51
2
You’re template has a syntax issue, paste it in here for us to see.
I’m trying to post it but the html code is messing up the post.
laf
29 November 2023 15:08
4
You need by putting your template between 2 sets of ```
Like this
Sorry, but I don’t understand. You seem to have the same problem I had when trying to add HTML code to the post.
Could you write it in a Text editor and paste a print screen like I did ?
laf
29 November 2023 21:45
6
You need to paste your template between 2 sets of ``` like I showed above, it will format correctly then
I’m still getting the error on all our templates. Here’s another similar error :
Here’s what I tried as pair of ‘’’ (by color) :
When you say “paste your template between”, I thought you meant what I did in green or orange, am I correct ?
laf
30 November 2023 17:00
8
No I mean paste your template into here as a comment.
OK here’s my template
{{ $alert->title }} <BR>
Date : {{ $alert->timestamp }} <BR><BR>
<div style="font-family:Helvetica;">
<h2>
@if ($alert->severity == critical)<span style="color:red;">{{ $alert->severity }}</span>@endif
@if ($alert->severity == warning)<span style="color:orange;">{{ $alert->severity }}</span>@endif
@endif
@if ($alert->state == 2) <span style="color:goldenrod;">acknowledged</span>@endif
@if ($alert->state == 3) <span style="color:green;">recovering</span>@endif
@if ($alert->state == 0) <span style="color:green;">recovered</span>@endif
</h2>
Équipement : {{ $alert->hostname }} <BR>
Description : {{ $alert->sysDescr }} <BR>
Type alerte : {{ $alert->type }} <BR>
Pourcentage de ping perdu : {{ $alert->ping_loss }} % <BR>
Durée de la panne : {{ $alert->elapsed }}
@endif
<BR><BR>
<img src="https://cssvt.gouv.qc.ca/wp-content/themes/cssvt/assets/images/cssvt.svg" width="186" height="64">
</div>
Sorry for the misunderstanding !
laf
30 November 2023 22:46
10
I didn’t notice in the earlier message, the actual error was in the message. You need to wrap critical and warning in quotes:
<h2>
@if ($alert->severity == "critical")<span style="color:red;">{{ $alert->severity }}</span>@endif
@if ($alert->severity == "warning")<span style="color:orange;">{{ $alert->severity }}</span>@endif
@endif
</h2>
@endif
<BR><BR>
</div>
Thanks, problem solved. I changed all our templates and checked the alerts and they’re working now.
system
Closed
8 December 2023 17:46
12
