| LibreNMS | 22.8.0 |
| DB Schema | 2022_07_03_1947_add_app_data (244) |
| PHP | 8.0.22 |
| Python | 3.10.5 |
| Database | MariaDB 10.5.16-MariaDB-1:10.5.16+maria~focal |
| RRDTool | 1.7.2 |
| SNMP | 5.9.3 |
[OK]
[OK] MySQl and PHP time match
[OK] Redis is functional
Hi
A little confused with Alert Templates with one of the outputs:
I am using the variable $alert->sysContact but it is not showing anything on the output.
e.g.
if ($alert->sysContact == ‘’) Contact: Unknown else Contact: {{ $alert->sysContact }} endif
(Had to remove the @ symbols on the if, else and endif
The output is coming out as Contact: Unknown when there is data in that field on the device.
I then check to see if it was a mistake on the if statement so I tried
But that came back as Contact:
I think it may be to do with the sysContact override which I am using on most of my devices as many of them are ping only thus do not inherit a sysContact.
All other parts of my alert template work ok producing all relevant data.
Is there a variable or syntax I am missing?
Thanks in advance.
