When trying to convert a HTML Alert Template from a legacy template I removed all the existing attached rules to that template and saved it to work on later. Now when trying to attach rules to the Default Alert Template or any other template I can’t as it says that the rule is used in template “undefined”.
validate:
| LibreNMS | 1.48.1-62-gfcb0b67 |
| DB Schema | 2019_01_16_195644_add_vrf_id_and_bgpLocalAs (131) |
| PHP | 7.2.15-1+ubuntu16.04.1+deb.sury.org+1 |
| MySQL | 10.0.38-MariaDB-0ubuntu0.16.04.1 |
| RRDTool | 1.5.5 |
| SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.8.4
I can’t see anyway to attach a template to the rules now as it won’t let me.
Many thanks,
David
