Hi Guys,
I checked the previous posts but I couldnt see any solution.
I have setup an ms teams alert transport, I click on the test button and it shows “transport to ms teams ok” but Im not getting any message on the channel. I see the below error on teams logs :
ExpressionEvaluationFailed. The execution of template action ‘Send_each_adaptive_card’ failed: the result of the evaluation of ‘foreach’ expression ‘@triggerOutputs()?[‘body’]?[‘attachments’]’ is of type ‘Null’. The result must be a valid array.
I tested directly a payload on the cli with the below command and i can see the message on teams
curl -H “Content-Type: application/json” -d “@/root/payload.json” “https://mywebhooklink”
any help with this one plz ?
Can you post your alerts template?
I’m using now emails alerts because I unfortunately gave up on trying to make it work with teams webhooks unless you have a better idea ?
my email template looks like below but thats irrelevant to my issue
| Severity |
State |
Timestamp |
Device |
Issue |
| {{ $alert->severity }} |
{{ $alert->state }} |
{{ $alert->timestamp }} |
{{ $alert->hostname }} |
{{ $alert->name }} |
It took me a bit to get my webhooks working. My webhook tested good however my alerts template wasn’t being received via teams. I re-wrote my alerts template and now all my alerts are sent to different channels on teams with different alert templates.
can you please post your template, I will test it and check if it works for me, many thanks in advance
Here is my default one. I typically modify for each alert to ensure I’m getting the data I want in the alert based on what the issue is.
{{ $alert->title }}
Severity: {{ $alert->severity }}
@if ($alert->state == 0) Time elapsed: {{ $alert->elapsed }} @endif
Unique-ID: {{ $alert->uid }}
Rule: @if ($alert->name) {{ $alert->name }} @else {{ $alert->rule }} @endif
@if ($alert->faults) Faults:
#{{ $key }}: {{ $value[‘string’] }}
@endforeach
Alert sent to:
@foreach ($alert->contacts as $key => $value)
{{ $value }} <{{ $key }}>
@endforeach
@extends(‘alerts.templates.default’)
Alert sent to:
@section(‘content’)
{{ $alert->title }}
@endsection
@endif
I try to use this one and when I click on update, the error message show up : undefined constant alert
how did you define this constant ?
