I am having some issues using the alert transport feature. The API I am trying to use requires a unique session-token each call. The session-token is given but how can I place the session token and run a new API in the same transport? The url’s seem to be different as well. http://IP/apirest.php/initsession will give you the session code however I need to post into the http://IP/apirest.php/ticket section. Any help would be greatly appreciated. Trying to post tickets to GLPI using GLPI’s API.
I think I need to do something like this:
$api_url=“http://localhost/glpi_pcpa/apirest.php”;
$app_token=“qHGjkP5EZ72al2uH0kANxrVk8iTY6L0hW6I6LwaZ”;
$user_token = “9paN3NW7bfDeGfVplYN01xKi6Qhy5sD2wG5cQIWq”;
$ch = curl_init();
$url=$api_url . “/initSession?Content-Type=%20application/json&App_Token=”.$app_token.“&user_token=”.$user_token;
curl_setopt($ch, CURLOPT_URL, $url);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
$json = curl_exec($ch);
curl_close ($ch);
$obj = json_decode($json,true); //{“session_token”:“qjr28v40kb88tucrpli2n0nupt”}
$sess_token = $obj['session_token'];
And call $sess_token in the head of the API section.
Just wanted to bump this to see if anyone had any thoughts!
