Alerting API limitation
Hi!
I have a issue with the alerts API (/api/v1/alerts?state=X), the issue is that when I do a GET method for this I get very limited amount of information. I’m using the API within a Python script to collect data from a customers LibreNMS to generate a report containing alerts from the previous week. However I need more information than which device is alerting, which rule it’s alerting on and at which time. I really need which component within the device that is alerting such as which port, which VLAN, BGP peer and so on
This is the information I recieve:
    "alerts": [
            "hostname": "X.X.X.X",
            "id": 83,
            "device_id": 13,
            "rule_id": 6,
            "state": 1,
            "alerted": 1,
            "open": 0,
            "note": "",
            "timestamp": "2024-07-06 13:16:04",
            "info": "{\"until_clear\":false}",
            "severity": "warning"
To try to solve this I also in run a get method towards the rule ID to get limited information about the alert, but I get no port and so on. I was thinking about using transports where Libre sends out information towards a database of sorts which the script then collects data from, but this is sort of a last solution for me.
If anyone knows of a better solution for this please feel free to share it!
Br,
Linus
