Hi.
So I have 2 wireless devices, both set with custom High & Low value for signal strength.
When one of the devices signal goes “out of range” I get an alert that both are out of range. (too high)
If I go to devices>alerts I can see only one alert for the one that should have an alert, not for the other, however I get notifications for both?
My rule is below, I believe it is a standard rule, could someone point me in the correct path?
%wireless_sensors.sensor_current >= %wireless_sensors.sensor_limit && %wireless_sensors.sensor_alert = "1" && %macros.device_up = "1"
