We had some issues with the upgrade to 1.44 and new Trasport setup. We got the upgrade working but since that point we have not been getting emails from the new Trasnport system.
This was previously working fine. The last time we received an email from the system was in Aug.
The point at which the email stopped was as follows;
The Auto update failed on Sat 18/08/2018 17:42
The following email was sent from the server
Blockquote
We just attempted to update your install but failed. The information below should help you fix this.
warning: unable to access ‘/root/.config/git/ignore’: Permission denied
error: Your local changes to the following files would be overwritten by
merge:
html/includes/common/top-devices.inc.php
html/includes/common/top-interfaces.inc.php
html/includes/common/worldmap.inc.php
Please, commit your changes or stash them before you can merge.
Aborting
Blockquote
warning: unable to access ‘/root/.config/git/attributes’: Permission denied
merge:
includes/definitions.inc.php
Aborting
I have checked through the syslog, mail.log, dmesg, mysql/error.log and can’t see any errors on there.
Testing the trasnport sends an email. If I test the transport as follows;
https://docs.librenms.org/Alerting/Testing/#transports
This also works.
However, live Alerts do not transport.
I have changed one of my rules so it triggers very easily.
However, If I check Recent Events for each one of those hosts I don’t see “Issued critical alert for rule”
The bottom host shows the following in recent events.
