Bounzz
13 November 2018 16:19
1
I have problem with AlliedTelesis Discovery.
When i try to discover same devices (AT-8000S), one appears as 8000S with Radlan OS and one appears as blank with AlliedWare OS
It’s exactly the same switch, with same version of firmware.
This is a bug ?
Thanks for your help
From where did you got that info? (the screenshot of the first post)
What is the correct OS? Radlan or Allied Telesis?
Bounzz
14 November 2018 07:45
5
The first sceenshot it’s allied telesis CLI
The correct OS is Radlan.
Bounzz
14 November 2018 07:49
6
Some 8000S use the correct Mibs
The issue here is the sysObjectID reported by the switch.
I’m not familiar with AT/Radlan devices but if they report different sysObjectIDs means they are different hardware. Even when “its not”.
Try adding:
- .1.3.6.1.4.1.207.1.4.127
To the list of sysObjects in your radlan.yaml file and rediscover that device (./discovery.php -h hostname)
Bounzz
14 November 2018 08:52
8
os: radlan
text: Radlan
ifname: true
type: network
icon: alliedtelesis
group: alliedtelesis
over:
- { graph: device_bits, text: ‘Device Traffic’ }
- { graph: device_processor, text: ‘CPU Usage’ }
discovery:
- sysDescr:
- AT-8000
- sysObjectID:
- .1.3.6.1.4.1.207.1.4.128
- .1.3.6.1.4.1.207.1.4.145
- .1.3.6.1.4.1.207.1.4.144
mib_dir:
- radlan
Radlan.yml already have this sysObjects
But when i discover, he seems to use allied.yml
.1.3.6.1.4.1.207.1.4.126 is not in radlan.yml but librenms see this as Radlan
My fault
In the allied.yaml, add - .1.3.6.1.4.1.207.1.4.128 to sysObjectID_except:
As an FYI:
The reason some low-end older Allied Telesis products such as the 8000S appear as Radlan OS is because the switch is a rebranded Marvell Switch. Marvell purchased Radlan back in 2003
I had some issues when cleaning up the Allied Telesis support in PR7670 and didn’t have access to all of the older products to determine just what the Sys ObjectID was for each one.
Have made PR9454 so this works out of the box for 1.3.6.1.4.1.207.1.4.128
Thanks,
Matt
Bounzz
16 November 2018 21:26
12
Hello Mattie
Thanks for the PR but can you add
1.3.6.1.4.1.207.1.4.125
1.3.6.1.4.1.207.1.4.143
It’s for 8000S and 8000GS
This OID is seen as allied but it’s radlan
