Like some posts found in this forum, I’d like to find a way to prevent brute force against librenms by using fail2ban with a fine grained control.
I can’t find any logs where failed auth are stored.
Could you help me ? Thank you
Regards,
Vincent
Component
Version
LibreNMS
22.11.0-9-g49abee372 (2022-12-01T15:20:49+01:00)
DB Schema
2022_08_15_084507_add_rrd_type_to_wireless_sensors_table (248)
PHP
8.1.11
Python
3.7.3
Database
MariaDB 10.5.12-MariaDB-1:10.5.12+maria~buster
RRDTool
1.7.1
SNMP
5.7.3
In the WebUI you can see the authentication history.
Hello SantiagoSilvaZ,
Thank you for your reply.
What I need is to give to fail2ban an access to the logs for parsing them and search for failed logins in order to ban ip.
Regard,
Vincent
In the case of authlog, it is being registered in the database, in the authlog table; I don’t know if it’s also available elsewhere.
Thank you for your reply. I’ll have a look in database and, why not, extract logs with a script then parse it.
Regards,
Vincent
You could also send a change request to log authentication failures to librenms.log, It would be a pretty easy change to make.
system
Closed
16 March 2023 15:07
#7
