Hello I was wondering if someone might be able to add support for the Alpha FXM HP ups units. These use the same software as the Alpha CXC HP controller, but the hardware is different. The CXC HP is a DC power plant, where as the FXM HP is an AC power plant.
The mibs are available here, I think the only one the FXM HP uses that the other one does not is the UPS-MIB. https://tools.alpha.ca/downloads/docs/MIBS.2024-01-26.zip
The main difference I see if it helps the hardware for the CXC HP comes up as HW: S1.I16.P31 where as the one for the FXM HP comes up as HW: S1.I21.P3
Thanks for any help you may be able to provide.
