Hi, Look like I am having issue with my git repo of librenms … Anyone can help me solve the issue? Here’s the output of the daily and validate…
[[email protected]_{{PROD}} ~]$ ./daily.sh
fatal: ambiguous argument 'HEAD': unknown revision or path not in the working tree.
Use '--' to separate paths from revisions, like this:
'git <command> [<revision>...] -- [<file>...]'
warning: ignoring broken ref refs/heads/master.
error: unable to resolve reference refs/heads/master: No such file or directory
fatal: Failed to lock ref for update: No such file or directory
fatal: Needed a single revision
fatal: No such ref: HEAD
You are not currently on a branch. Please specify which
branch you want to merge with. See git-pull(1) for details.
git pull <remote> <branch>
Updating Composer packages OK
Updated from unset to OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
[[email protected]_{{PROD}} ~]$ ./validate.php
LibreNMS | 1.54
DB Schema | 2019_07_03_132417_create_mpls_saps_table (139)
PHP | 7.2.18
MySQL | 5.5.60-MariaDB
RRDTool | 1.4.8
SNMP | NET-SNMP 5.7.2
[OK] Composer Version: 1.9.0
[FAIL] Some devices have not completed their polling run in 5 minutes, this will create gaps in data.
Devices:
10.250.133.238
Check the cron job to make sure it is running and using discovery-wrapper.py
[FAIL] DateTime::__construct(): Failed to parse time string (@) at position 0 (@): Unexpected character
You can switch back to master with git checkout master
Files:
/opt/librenms/rrd/10.248.32.1/poller-perf-mpls.rrd
