Fresh/Clean install.
followed steps from Install LibreNMS - LibreNMS Docs
Centos8 & apache
Get to the end of the instructions, with no errors.
when trying to connect to the web ui to complete I get a error
Service Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
if I run validate.php I get
[librenms@rconfig ~]$ ./validate.php
Component | Version |
LibreNMS | 21.7.0-29-gb9e6a5975 |
DB Schema | Not Connected (0) |
PHP | 7.3.20 |
Python | 3.6.8 |
MySQL | ? |
RRDTool | 1.7.0 |
SNMP | NET-SNMP 5.8 |
[OK] Composer Version: 2.1.5
log shows…
[2021-07-29 14:32:48] production.ERROR: Not enough arguments (missing: “setting”). {“exception”:"[object] (RuntimeException(code: 0): Not enough arguments (missing: “setting”). at /opt/librenms/app/Console/Commands/GetConfigCommand.php:52)
[stacktrace]
#0 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): App\Console\Commands\GetConfigCommand->handle()
#1 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Util.php(40): Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
#2 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\Container\Util::unwrapIfClosure(Object(Closure))
#3 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(37): Illuminate\Container\BoundMethod::callBoundMethod(Object(App\Application), Array, Object(Closure))
#4 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Container.php(651): Illuminate\Container\BoundMethod::call(Object(App\Application), Array, Array, NULL)
#5 /opt/librenms/vendor/laravel/framework/src/Illuminate/Console/Command.php(136): Illuminate\Container\Container->call(Array)
#6 /opt/librenms/vendor/symfony/console/Command/Command.php(299): Illuminate\Console\Command->execute(Object(Symfony\Component\Console\Input\ArgvInput), Object(Illuminate\Console\OutputStyle))
“librenms.log” 19L, 3231C
As test I created a html file in the html directory & it is presented in browser, so web service looks to be running fine.
help?
